Dagwood_55's avatar
Dagwood_55
Big Time Wiring Problem..
Just before leaving on a trip yesterday, I checked my battery level with a meter and all was well.
Then after arriving and during set up, I noticed my water pump and air conditioner did not work at all, but the AC lights did work when hooked to my genny.
I eventually opened the battery door where I see the battery wires are totally burnt and toasted. I then go inside where the battery wires go to and see a rats nest of burnt wires, all DC I believe. They are so bad, it is hard or impossible to tell what goes where. I'm really suprised the camper did not burn to the ground.
So, how do I fix this?? The camper is an older Layton 2515 small 5th wheel. Is there a wiring diagram?? Or a generic diagram?? Is it possible to fix without a electrical engineering degree??
Since its an older camper, I'm not willing to put much into it as I've already spent twice what it's worth to date. Possible I need to cut my loses and salvage it out.....
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
