- bukzinExplorer
BFL13 wrote:
I think Fisherguy runs his PD9280 (non-PF corrected) with his. Probably can run the PF corrected PowerMax 100amper or WFCO 68100.
For near max load with a cold gen I recommend leaving Eco off at first, then turn Eco on a few minutes later.
What is PF corrected?
Thx - BFL13Explorer IIThis is with a Honda 3000, but it shows how you can get more charging amps using a PF corrected charger. (from a post in September)
The Honda can do a max of 130a worth of non-PF corrected Vectors before popping its breaker. I also have the PowerMax 100 amper which is PF corrected
---tried how many Vector amps I could run as well as the 100amper. It did 50a of Vectors and one more amp (seemed like) popped the Honda. I also have the rig's shore power on the Honda but with nothing much on. I turned on the laptop with that 150a on there and the Honda popped.
So that means I think that the Vectors have a power factor of 0.8
This might be all wrong, but where, of that 130 all Vector, now there is 50, so 80 more Vector is the same as 100 more PF corrected PM, so to me that means 100=80. ???? That would compare with the reported 0.7 PF of a typical converter.
I figured after the amps had tapered on the 100amper, I could add more Vector, but not amp for amp due to the PF on the Vectors. (a 40 and a 35)
I was able to do this:
Start: 100 PM, 40a VEC, 10a Vec
Then: 85a PM, 40a VEC, 20a Vec
Then: 65a PM, 40a Vec, 35a Vec - MM49Explorer
ktmrfs wrote:
pianotuna wrote:
Hi ktmrfs,
When I wrote PD they told me all their units are a power factor of 0.7. So the 1300 watts becomes about 1857 va. Not pretty with a genny rated for 1600 va. Then take it up above sea level. If the battery bank is truly flat with six six volts it is not going to be reliable.
The only reason it would work is if the pd doesn't zip up to full output i.e. with sagging voltage. I have seen that in person with the 40 amp pd in the RV I call home probably because the maker skimped on the wire size from the converter to the battery bank.
The person might consider solar?ktmrfs wrote:
True, the PD80 may draw about 1300 watts, but closer to 1600-1700 VA, so it's marginal on a honda 2000, right at it's continous rating. Like so many RV appliances, actual current draw is more than the "watts" rating indicates.
The PD60A draws on the order of 1400VA IIRC my measurements on one supplying 55A.
Thanks for the info and Wow, Looks like the PD80 is worse than I thought for draw!. I see why it requires a 20A circuit.
Sure am glad now that I went for the PD60A instead of the PD80. It's fine with the honda 2000 and my bank of 4 GC even at altitude. But it does give the honda a workout.
If I really need to "poor the coals" to the batteries, I dig out my second honda, parallel them and fire up the PD60 in the pass through and the PD55A in the panel and hit the batteries with about 110A. That combo will hold high current for quite a while before it starts to sag.
Good to hear what is really working. The modern inverter generators do one thing perfectly; they protect themselves! It wold be a shame to buy all this high price equipment and find out that the generator kicks out because of an inductive load spike. The real test is Joe consumer using it. My application is a PD9140 w charge wizard with a Honda Eu1000i against a group 27, 12v batt. Then gen runs at about 1/2 throttle Let's hear what people are using!
MM49 - ktmrfsExplorer III
pianotuna wrote:
Hi ktmrfs,
If I really need to "poor the coals" to the batteries, I dig out my second honda, parallel them and fire up the PD60 in the pass through and the PD55A in the panel and hit the batteries with about 110A. That combo will hold high current for quite a while before it starts to sag. - pianotunaNomad IIIHi ktmrfs,
The PD60A draws on the order of 1400VA IIRC my measurements on one supplying 55A. - ktmrfsExplorer IIILand:
Since it sounds like they haven't bought a generator yet, I'd suggest they look at yamaha's as well. The yamaha 2400 should be able to either
(a) handle a bigger converter
(b) let them run a PD80, powermax 100 and have some spare power for other stuff that might be on like charging a computer, etc. - pianotunaNomad IIIHi land,
1440 is 90% of the rated output at sea level. He isn't. It would be better to aim at 80% of the rated output for continuous use. - BFL13Explorer IIFisherguy Vancouver BC
Senior Member
Posted: 08/21/11 11:12am Link | Print | Notify Moderator
I have a 2000 watt Honda, I just make sure the fridge is set to GAS and have no problem driving my PD9280. Makes the Honda work a little for a while though.
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, SteadyFast stabilizers, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600, shocks and EZ-Flex suspension, Reese Strait-Line
I can't find his graph right now but the PD9280 went into boost at 14.4 ok if anybody was wondering about that aspect - ktmrfsExplorer III
wa8yxm wrote:
3 pair of GC-2 batteries can suck about 180-200 amps of power if you can find a converter that big.. I do not think you will.
A 1,000 watt GENRAC portable generator (True 1,kw) can power a PDI 9180 with a single pair of dead GC-2's. I know. I killed them and restored them to charge.
I would say 150 amps is possible with a Honda 2000, (Not a true 2kw generator)
But I do not think you will find a converter that big.
I'd say that generator is very conservatively spec'd, kudos to them. It' actually cranking out about 1600VA with the 9180 hooked up and full output.
With most honda 2000's It's very hard to get them to hold 2000VA for more than a few seconds in most cases, 1800VA for more than a few minutes.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
