dclark1946
Dec 08, 2014Explorer
Incidently the B&D 18V products are going away. If you want to keep using your 18V products you should consider buying some replacement batteries while they are still available. I have started rebuilding mine with Sanyo 2.4AH cells. I have done two so far and have enough cells to do two more. Run time has significantly improved compared to the standard B&D 1.5AH battery. I have too many 18V products that I use on a regular basis to switch over to something different.
Dick
Dick
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
