Old-Biscuit
Mar 07, 2016Explorer III
Factory flush spray nozzles can be glued to tank OR they can be spun at high speed which melts plastic and 'welds' them to tank
When holes in spray nozzle get clogged (usually from hard water minerals drying out inside nozzle) they are virtually useless.
Now that you have hose cut off you could try filling hose with CLR and let it sit/soak
If it is an aftermarket kit then spray nozzle will be installed using screws/sealant
If you can't get to it to remove.....abandon in place and install new
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
