pushtoy_2's avatar
pushtoy_2
black tank chemicals
what kind of wast digester does everyone use?? iam wanting to switch i am using ODERLESS it doesnt seem to be working.. iam not a full timer but useto be can i get some feed back please
  • sgfrye wrote:
    way2roll wrote:
    Plain water. If you use enough water and flush your tanks, you don't need any chemicals. The length of time any solids are in your tank isn't nearly long enough for any enzymes to really do anything and they just end up in the recipients' septic system. Been using plain water for the past 7 years and never had an issue. I did install back flush systems on both grey and black and I can say it makes things much easier.
    x2
    X3
    If you're getting odors, it more likely a venting problem.
    x2
  • Plain water. If you use enough water and flush your tanks, you don't need any chemicals. The length of time any solids are in your tank isn't nearly long enough for any enzymes to really do anything and they just end up in the recipients' septic system. Been using plain water for the past 7 years and never had an issue. I did install back flush systems on both grey and black and I can say it makes things much easier.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 23, 2025
