pushtoy_2
Feb 10, 2020Explorer
black tank chemicals
what kind of wast digester does everyone use?? iam wanting to switch i am using ODERLESS it doesnt seem to be working.. iam not a full timer but useto be can i get some feed back please
Lwiddis wrote:
Lots of water, fill before you dump, dump often and add four or so gallons after dumping. No chemicals needed.
way2roll wrote:Same here. The chemicals smell worse than the waste. It's a holding tank not a septic tank.
Plain water. If you use enough water and flush your tanks, you don't need any chemicals. The length of time any solids are in your tank isn't nearly long enough for any enzymes to really do anything and they just end up in the recipients' septic system. Been using plain water for the past 7 years and never had an issue. I did install back flush systems on both grey and black and I can say it makes things much easier.
way2roll wrote:Naio wrote:
I'm using a cassette toilet for the first time this year. Happy Camper made an enormous difference in the smell when I empty it. Very little smell now.
I assume that when it says organic it means in the chemical sense, carbon-based, rather than in the no pesticides sense. (And yes,the definition of organic for foods is very tightly regulated.)
Formaldehyde is a carcinogen.
I find it hard to believe that anyone is going to breathe enough sewer gas to get hydrogen sulfide poisoning.
Per the FDA - "FDA does not regulate the use of the term “organic” on food labels. "
Lots of things are organic, that doesn't mean they are healthy. Asbestos is organic, so is Arsenic.
And getting to the nitty gritty, the fairly dramatic warning label on Happy Camper says (paraphrasing) " Avoid contact with eyes, avoid prolonged contact with skin, do not swallow, avoid breathing dust, wash thoroughly after handling, flush thoroughly for eye and skin contact, get medical attention if any of the above occur"
You get the point. Doesn't sound so warm and fuzzy to me. The fact there are all these warnings and unnamed ingredients - no thanks. Sounds more like they don't want to tell you whats in it and they don't have to since you don't eat it
and they use "organic" because it's a marketing tool. If a product that's used to treat a condition invites greater risk than the condition itself - I'll stick with water.
