BFL13
Jul 01, 2020Explorer II
MrWizard wrote:
"I think the vents open pointing aft so the lid won't blow off if you leave it open a bit while driving. With the vent hood on, that lid should be safe from blowing off."
If the vent lid is open when driving
You will have a ram air scoop into the bathroom
True. So closed while driving even with vent hood. It could go on sideways as was mentioned. I could make the tank vent a little taller too a bit higher than the vent hood.
It is not that bad so an Air Wick or whatever they are called would probably do it too. I will do some more work on the drains etc and see how it goes. Meanwhile they finally are opening the campground we like to use in the summer with the Class C, so there's that! :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
