BFL13
Jul 03, 2020Explorer II
I now see that the grey drains do not go into the black tank at all, so the black is all on its own. Not sure how the sinks and shower drains are vented. Double kitchen sink so that might be it for there if you don't plug both. Bathroom shower could vent via bathroom sink not plugged. No air admittance valves anywhere in the pipes past the Ptraps. (1991 RV)
Good idea for a shower drain plug. You have to stand in the shower pan while at the bathroom sink. This is not a 5er! :)
Got the drains all cleaned out so have to do a smell test later. The black tank is all cleaned out too so be a while before any tests.
I have to rig a second tank under the TC overhang behind the truck bumper to be the grey tank. I did that before with our previous TC. Fairly simple job where it can be hanged from above and supported below with a towing piece in the receiver with a plank over to the side attached using the hole where the ball normally goes. Just have a short hose that goes from the sani-cap down to the grey tank. A tap to dump it if it doesn't have one.
A plastic bigger gasoline can works for that if on it side. Its pouring hole on top to take the grey filling hose, and leave its vent screw- on cap at the bottom to be unscrewed as the drain. Good enough for sinks, but not big enough for shower of course.
