fourthclassC
May 31, 2020Explorer
Howdy, I thought I'd share my experience here. I had some leakage by the valve which made taking the cap off unpleasant. I changed the seals. seals only. This did not leak for about a year. Then it started leaking again. Just a little. So I think the blade itself is scored up from sand in the tank at some point. I think that if I change the entire valve (not just the seals) it will stop and last a long while without leakage/seepage.
