lanerd
Jul 16, 2013Explorer II
THIS is the flush king. The advantage to this item is that you can connect your rinse hose to it and push water back up the drain pipe into your black tank. Normally, the opening (connection) between the tank and drain pipe will clog with tp or other waste and not allow the tank to drain. The flush king will force this obstruction back into the tank.
Your built in rinse feature allows you to put water back into your tank also, but does not go through the tank/pipe connection. It typically will have a sprayer inside the tank and it will help to clean the inside of the tank.
Walmart sells a device much like the flush king but does not have the attached gate valve to it. However, it too will force water back up into the tank via the tank/pipe connection and will serve the same purpose as a flush king. About half the price.
Hope this helps
ron
Hope this helps
ron
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
