skipnchar
Jul 16, 2013Explorer
I SUSPECT others have identified your problem but you MAY have an increased problem now by the use. If the previous dumping allowed only the liquid to drain (likely if it's a cut out obstruction) then the solids are now built up behind the blank that was originally closing off the tank. Get it back to the dealer and let him fuss with it because it may be an UNSANITARY job to get the blank removed with a clog behind it. REMEMBER too that in order to assure no OTHER clogs, NEVER leave the black tank dry (you did well on that) and NEVER dump a tank that is not close to full and ALWAYS use lots of water when flushing.
Good luck / Skip
Good luck / Skip
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
