- beemerphile1ExplorerCould the tank be full?
- drcookExplorerYou could put some water in it and rock the trailer back and forth so the water sloshes to help break up the plug if it is really bad. we had a Forest River that for some reason allowed the paper to plug up after just a couple uses. I poured water (clean) from a bucket held up high with the toilet valve held open to get some velocity. it took a couple bucket fulls, but it finally broke up and drained.
After that I had my wife and kid use more water. - path1ExplorerI got tired of trying to get females using more water. After flushing out tank I now fill the bowl up 3 times with water to the rim to get a jump start on the "not enough water" issue. If you don't have any other problems this works great. Regular "septic safe" paper for us.
Now I get
- Tacswa3ExplorerJust returned from my maiden voyage with my new TT. I somehow developed the pyramid below the toilet drain in just 2 days. Drain valve was closed. After finding toilet paper still in toilet a couple of times after a pee flush I can only assume the wife didn't use nearly enough water with flushes.
Tank drained fine but had to use a stick to mash **** down and thank goodness for the black tank Flush. - 2oldmanExplorer IIDon't know yet exactly where the blockage is, or whether it's a pyramid.
- donn0128Explorer IIDont poo in the tank? Females need to learn to use waaayyy more water. Dry flushing is the absolute worst thing you can do. BTW the holding tank when properly used is just fine for poo also. Your going to have to spend a lot of time flushing the tank to try and disolve your pyramid of ??
- westendExplorerYou probably have a pyramid of solid stuff directly under the toilet drain pipe. You will probably need to drain your tank and wash away the pyramid with a water wand and hose. Adding a bit of water softener or soap will help to move along any solids in the tank.
- Happycamper30ExplorerValves were closed, and I know it's just toilet paper don't **** in it, I used the end of a broom handle and probably pushed it down more
- PenManExplorerIs it really the toilet plugged or is it the black tank? Need more info.
- rockylarsonExplorerJust to get the discussion going, have you had the black tank dump valve open while the toilet was in use. That's a no!no!. Only open the dump valves once the tanks are close to full. Take it away everyone.....
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
