McGoo's avatar
McGoo
Black water valve hard to open!
My black water valve has become extremely hard to open and I fear it will break when using such extreme force. Is there a way to lubricate it? It is sealing fine and not leaking and otherwise does not need replacement.
  • Ditto X10 on using Silcone Spray on rod.
    First run a toilet or bottle brush around where the blade closes. Junk gets stuck in there and makes it hard to close. Of course only do this with the tanks empty! :W
  • When next time you empty, spray silicone lube on the handle shaft. If this does not do the trick, try what Ron suggested.
  • What I do with mine is when I have the tank empty, I will remove all fittings so I can have access to the valve gate inside the pipe and shoot it with silicone spray and work the gate back and forth a few times. Sometimes I will find tp stuck to the grooves the gate fits in and will remove that prior to spraying the silicone. Works for me.
    Ron
