McGoo's avatar
McGoo
Black water valve hard to open!
My black water valve has become extremely hard to open and I fear it will break when using such extreme force. Is there a way to lubricate it? It is sealing fine and not leaking and otherwise does not need replacement.
  • Ditto X10 on using Silcone Spray on rod.
    First run a toilet or bottle brush around where the blade closes. Junk gets stuck in there and makes it hard to close. Of course only do this with the tanks empty! :W
  • When next time you empty, spray silicone lube on the handle shaft. If this does not do the trick, try what Ron suggested.
  • What I do with mine is when I have the tank empty, I will remove all fittings so I can have access to the valve gate inside the pipe and shoot it with silicone spray and work the gate back and forth a few times. Sometimes I will find tp stuck to the grooves the gate fits in and will remove that prior to spraying the silicone. Works for me.
    Ron
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
