K Charles: I'll check the clearance and see what's what. Cheers.
Chum Lee: Fair enough, but still pretty oily. I can squeeze it out from the paper filters foam edge. (not the sleeve, but the foam attached to the filter edges that seat against the housing). When I run a towel into the filter grooves it comes out oily. Not sure if that is the way it should be or not. Overreacting?...possibly. All I know is it had never done this prior. She is running fine, no smoke, or at least none that makes me worry. It starts fine, the output is fine.
You know you are blowing my chances of convincing my wife we should have this:
http://www.centralmainediesel.com/order/Perkins-6-kW-Diesel-Generator.asp?page=P6125
I'll get another filter and see.
