retiredtraveler
Oct 03, 2013Explorer
Winterizing by blowing out lines
Hi All,
Although we are going south in late November I would like to blow out the water lines. The only compressor I have is a small 120 unit designed to blow up tires etc. In other words high pressure, low volume. My thought was to buy a portable air tank (7 gallon from Home Depot about $30). I would pressurize the tank to 40-45 PSI and use it to blow the lines. I realize that most likely I would have to fill the tank several times to get the job done.
I was at my RV dealer yesterday on other business. I explained my plan and was told I was crazy "Not nearly enough air in there to do it"
So, any experiences with this kind of approach?
Thank you in advance.
Keld
Keld
