Nvr2loud's avatar
Nvr2loud
Explorer II
Oct 30, 2013
Blowing out water lines for winter storage.
Last night I decided to blow air through my water lines to drain for winter. I started with the low point drain caps both off.
I used the blow-out attachment to connect my compressor to my city water hook-up connection. I closed all taps, closed the fresh water tank supply hose, and opened my hot water bypass (closed my hot water feed valves, hot and cold, since my hot water drain plug is removed)
Turned up the pressure and lots of air / water came out the cold water low point.
Next, I closed the cold water low point and turned up the air pressure again.... My trailer just held the 60 psi of air pressure. I switched the position of the bypass valve and nothing changed.. I'm confused about what is happening. It appears like the bypass is not bypassing, but it allows water past during normal operation??? Am I missing something here or do I have some sort of blockage (ice, debris) that may be plugging up my air line enough to hold 60 psi back.
