tenbear
Oct 07, 2013Explorer
McKenziek wrote:tenbear wrote:
Did your levelers work with the #6 wire before you changed the converter? If they did, the #6 wire is not the problem. Look for a wireing problem.
OTOH, if you replaced a Magnetek/Parallax converter with a PD9260 or similar converter, you might want to replace the #6 wire to reduce the voltage drop when charging the battery
The levelers worked fine and what you stated makes sense. I will double check my wiring but why would everything work fine until I level?
The wiring problem (short???), assuming that is what it is, only becomes a part of the circuit when the power is applied to the levelers.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 26, 2026
