Our GFI blew when we plugged into a park in Iowa and the 50 amp breaker tripped. We had to get the GFI replaced because it would not reset. Now about a month later the GFI has blown again and will n...
GFCI receptacles must have power to reset. You could have a tripped circuit breaker. Reset all circuit breakers. Turn them all off applying light pressure toward off. Then turn on main circuit breaker, followed by branch breakers. If rig has inverter, check the breakers on it.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
