Our GFI blew when we plugged into a park in Iowa and the 50 amp breaker tripped. We had to get the GFI replaced because it would not reset. Now about a month later the GFI has blown again and will n...
The GFI has it's own breaker. Because they blow so much the breakers get tired. It will "look" like the breaker is ok but they partial break. Shut all the breakers completely off and then back on again.
AND
Same thing happened to me and this is what I found behind the wall of the GFI. Check all the wires leading to it. Mine actually started on fire.:(
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
