Our GFI blew when we plugged into a park in Iowa and the 50 amp breaker tripped. We had to get the GFI replaced because it would not reset. Now about a month later the GFI has blown again and will n...
GFCI's have the ability to protect things down line form them. If there are other outlets wired to the output of the GFCI then something else on that circuit may be causing it to trip. Most common things are refridgerators and water heaters but even an outdoor outlet that has moisture in it can cause the trip.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
