StirCrazy
Apr 23, 2023Moderator
pianotuna wrote:
Hi All,
My solar panels were covered in snow this year.
The result was the house batteries got down to below 8 volts.
The sophisticated charger in the Blue Sky refused to send power to them.
The dc to DC unit finally got the voltage up high enough that the Blue Sky could log on. it happened at about 11.9 volts.
How thick was the snow Don? Im curious as I have seen charging through a bit of snow and want to know how much it takes to shut it down.
If you would have had LiFePO4 your BMS would have shut them down and protected them from over discharge you know ')
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
