BFL13's avatar
BFL13
Explorer II
Mar 03, 2021
Bluetooth Adjustable Converter?
As a sort of rv.net tech issues survey, would you like your converter to have a bluetooth module that you could set the charging parameters Vabs and Vabs timing to any voltage and time, kind of like this? :
Most converters are not adjustable, but do not meet many typical battery charging specs, which can be frustrating. If a solar controller or the charger in an inverter/charger can have this, why not a converter?
Would you use it if yours had it? is the question. Thanks.
https://www.custommarineproducts.com/uploads/1/4/3/7/1437708/using_the_ep_controller_bluetooth_app_19.pdf
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
