joshuajim's avatar
joshuajim
Explorer II
Sep 05, 2018
Boiling point of anti freeze
I flushed and refilled my trucks radiator today. I noted on the bottle that a 50/50 solution of antifreeze/water will result in a 256 degree boiling point. This piqued my curiosity so I did a little research. In reality 50/50 antifreeze only raises the boiling point by 8 degrees. The 15# cap on the radiator is what gets you to 256.
  • Very good observation. Now for the fun part. Radiator caps as they age, tend to loose their ability to hold pressure in a cooling system. Caps should be replaced every couple years. Most people never do however. Mine goes in the trash every 2 years. That is especially important with a diesel motor as loss of pressurization of coolant can result in hot spots on the cylinder liners and big mechanical repairs.
    All for a 6 buck part.
  • At 10,000 feet that temperature drops to about 237 degrees f.
  • Good to know. Especially when I'm watching my coolant temp underway.
    Thanks.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
