joshuajim wrote:
I flushed and refilled my trucks radiator today.  I noted on the bottle that a 50/50 solution of antifreeze/water will result in a 256 degree boiling point.  This piqued my curiosity so I did a little research.  In reality 50/50 antifreeze only raises the boiling point by 8 degrees.  The 15# cap on the radiator is what gets you to 256.
:) Hi, this is how it works:
Water boils at 212 degrees.
A 15lb. pressure cap increases this to 3 degrees per pound. = 45 degrees.
Now you are up to 257 degrees.
With all of the above and a 50/50 mixture of coolant, you can add another 30 degrees. This gives you a grand total of 287 degrees before puking into the street.
This information was from a General Motors school while explaining that GM's idiot light comes on at 261 degrees. And if this vehicle only has water and a 15 lb. cap, (no coolant) it can boil over and the idiot light will never come on.
