Lwiddis
Nov 15, 2020Navigator
Your average won’t be 30 amp hours per day for each 100 watt panel. When in bulk charging you might see 5 in bright light and cool temperatures for a while but as you enter the absorption phase the accepted power goes way down. Solar panels are cheap and rigid panels last a long time. Minimum is one solar watt per battery amp hour. Not the time to go cheap...and barely adequate. Use big wire...bigger wire.
I have two Trojan T125s and 245 amp hours when they are full. I use 75 to 100 amps per day mostly depending if I can get local TV news and if I run the Fantasic fans.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
