sleepy
Jul 20, 2013Explorer
Your fridge controls and propane detector use 12VDC all of the time
Can you get to shore power... ? (50Watt panel will not fully charge 2 batteries)
if so, fully charge your batteries to 14+ VDC
turn of your solar panel if you have a controller with that option... or disconnect the solar controller from the batteries
Observe over night... rules out the batteries hopefully
second night... have batteries fully charged by the shore power... then after dark... reconnect solar panel...
observe
if the batteries then drop you probably have a diode problem in your controller... and it should be replaced
Report your observations back here as you go... there are some good people on the forums... and some guess. Don't take guesses or at least the ones that cost money
sleepy
observe
sleepy
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
