hmknightnc
Jul 20, 2013Explorer
campermama wrote:
And now a cloud passes over and the battery voltage drops, that should not happen.
From your description of previously using your solar power successfully this indication says something else is wrong, you need to check:
-New controller is wired up correctly. Battery to battery terminals and solar to solar terminals. Remove the little metal jumper for flooded batteries.
- Unknown new draw in the system. Check for a light or instrument panel running that wasn't before. Something
- Your batteries are simply not charged enough and that little solar can't recover them. Get to shore power and recharge then try again
- Your batteries are failing.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
