hmknightnc
Jul 20, 2013Explorer
campermama wrote:
I did this when I noticed the drain, the batteries then seemed to drain "normally" or at least at a slower pace.
With the battery completely disconnected it should have settled down to 12.6 or so volts and lowered to that value very slowly. You are experiencing the classic symptoms of depeleted or failing batteries. You have to do two things in order for us to try to help you
1.) Check your solar controller wiring setup to make sure it is correct
2.) Get your batteries fully charged and that little 55 watt solar is not going to do it from a depeted state. It will at best maintain your batteries while boondocking. Your going to probably need at least 2 days plugged into shore power/generator.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
