MrWizard
Jul 20, 2013Moderator
load terminals are for something you wish to power from the battery
like a 'security light at night'
batteries should be connected to 'battery'
solar to solar/'input'
and if there is an option switch, turn load 'OFF'
if a cloud passes over and 'solar charging' (reduces/stops) then you are running on strictly battery power, so yes the RV monitor panel reading is going to change and show 'what it thinks the battery level is' , which is usually optimistic, so fair on the RV monitor panel is actually "POOR"
campermama wrote:
Ok first of all please reread what i wrote......the cheapy controller that was given to me worked better the the new NOT CHEAPY one I have now!
I expect voltage to drop over night due to fridge etc running, but not to drop the way it is because a cloud passes over! How can a battery go from good to fair in a matter of 20 minutes? Something isn't right.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
