hmknightnc
Jul 21, 2013Explorer
pianotuna wrote:
Hi,
There is one last thing to try with the solar. Just direct connect the solar panel to the battery bank. You will have to disconnect manually late in the day, say an hour before sunset
That's a good idea too. Keep an eye on the battery voltage, let it get to around 15volts or so and then disconnect if it will go that high
For the generator, you could try removing the spark plug and then see if you can pull the starter. If that works put the spark plug back in and try to start it then. Doubt if this will help but certainly worth trying.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
