dougrainer
Aug 23, 2014Nomad
Need more info. Model numbers and brand of the roof AC units. What is the outside ambient temp where you are at. There are some RVP AC units that are lo amp draw units, about 11 amps with fan AT 95 DEGREES AMBIENT. For each drop in temp of 10 degrees the compressor will pull 1 amp less. SO, if your ambient is 75 degrees, those AC units will pull 9 amps each. Doug
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
