dougrainer
Aug 24, 2014Nomad
RV daytrader wrote:
OK...each compressor pulls 7.8 amps and each fan FLA is 2.9...that is the MAX they will pull. In real life those compressors will pull around 7 amps and the fans about 2 amps...on a real hot day the compressors will pull close to the max, but on a cool day the amp draw will be less....if started seperately I can see this happening....
No, there is NO MAX limit. Just as each 10 degrees ambient colder than 95 will pull 1 amp less, each 10 degrees ABOVE 95 will pull 1 amp MORE. Doug
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
