SidecarFlip wrote:
They appear to be model specific to me and rather expensive too.
Not cheap. You get one A-Dapter with the Bleeder, then in my case I'd need two more to do Jap Car, Jap Truck, Ford Minivan, Ford E450, Surge Braked Boat Trailer. Three would do all those.
An OP here uses one as a pressure source only, takes it off and fills the master cylinder as needed during the process.
I heard this tip that I consider Very Good for MityVac Bleeding: Remove and Clean the Bleeder Screws. Then apply Permatex to the threads and re-install. Keeps air from being drawn past Bleeder back in to Caliper/Cylinder. Might also make it a little less likely for Bleeder to rust in place.
