My 2010 Ford setup tells me on the Console information panel that the Brake Controller is not connected. I suppose it makes a small DC current measurement to determine this...
I also can determine if the brake magnets are activated by using a simple boy scout compass up close to the wheel. It will deflect the compass needle...
My fifth wheel setup make a low pitched tone noise if you listen real close to the wheel with the Brake Magnet engaged...
A real test would be using a DC Current clamp on meter around the brake magnet wire as each Brake Magnet should draw 3AMPs DC current for each wheel when engaged with the slider switch (Full 12VDC)... That will be 6AMPs for one axle or 12AMPs for dual axles...
Everyone you talk with says be sure to check the wiring where it goes into a hole in the axle to go from side of the the trailer to the other. I guess the hole may scrap away the insulation perhaps...
Roy Ken
