BFL13
Mar 13, 2014Explorer II
ScottG wrote:
The brakes will work surprisingly well if covered by grease. They may also run hot if contaminated.
BTW, did you read my previous post regarding the Voyager?
Yes I have the Voyager, but if I am getting the correct voltage as far as the blue wire in the trailer's cord and am getting humming on the wheels, does that not indicate the controller is working?
I might have a problem between the magnets and the shoes actually doing anything? If I can show the electric side is ok, then I will have to go and get the hubs pulled and all that. I see the Dexter manual has a trouble shooting guide that kind of takes you there if the electric tests prove out. But I had hoped my breakaway test eliminated that as an issue. No?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
