BFL13
Mar 19, 2014Explorer II
ScottG wrote:
The brakes will work surprisingly well if covered by grease. They may also run hot if contaminated.
BTW, did you read my previous post regarding the Voyager?
Did some more trouble shooting, eventually found that the voltage on the blue wire only went from 0-5 volts with the gain at usual setting.
That voltage should go to 12v, which it did when I turned the gain to max. Now I get braking again just right, but with gain at max.
It was mentioned there is a part in the Voyager that weakens over time. Is this my situation? If it weakens more I can't turn up the gain more.
I am thinking I ought to have a "spare" handy in case the Voyager quits entirely while we are on a trip and it is not so easy to get one right away. There is a sale on locally for a controller that I would like some opinions on please:
http://www.princessauto.com/pal/en/Brake-Controllers/Brake-Force-Time-Based-LED-4-Brake-Controller/8023523.p
http://www.etrailer.com/faq-brakecontroller.aspx
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
