fitznj
Mar 07, 2019Explorer
Brake pedal should go down slightly when the engine is turned on. From
what you've written, it sounds like the master cylinder is okay;
My next thought is that maybe you overheated the brakes prior to your incident. This would have raised the temp of the brake fluid.
Try bleeding the brakes and see if you spot any air bubbles.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
