I have just done a complete brake bearing repack and adjustment. Done it many times. Took 5th wheel for a test run and did a number of braking at different speeds. I went around and felt all brake h...
Jack up that wheel and test braking by briefly pulling the breakaway switch. If the wheel can't be turned, the brakes work but they still may have a problem with grease or other issue. Check the adjustment while up. Next step would be pulling the drum.
Also consider the possibility that the other three are adjusted too tight.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
