My fifth wheel breaks aren't working, hardly feel a thing from them at max....pulled one wheel off and have found grease inside the drum and on the brake shoes....it appears all four are the same. Th...
I would check the application for the axle rather than # on present seal when buying new seals. It's possiable your seals are in good condition but wrong type. Since they are sometime confused,it is worth mentioning Dexter E-Z lube hubs vs Bearing Buddies. One might be instructed by an E-Z Lube owner to add new grease until old grease comes out around outer bearing. That is correct for E-Z but if the unsuspecting diy has Bearing Buddies,grease will likly go past seal and into drum.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
