camperkilgore
Sep 25, 2015Explorer
Coolerman wrote:
OK here is the finished wiring shots:
J-Box with terminal strip...
Left side brake wiring...
Old system voltage (truck running) at right rear brake magnet (furthest from TV connector) was 12.9. With new wiring 13.4 enough difference to make it worth while in my opinion...
I did similar to yours with the junctions boxes. Used outdoor boxes with gaskets to seal up the boxes I didn't use terminal strips however. Wish I had. I just used wire nuts. I did use underground sprinkler wire nuts which are made for wet environments. They have a silicone(I think) stuff in the wire nuts which eliminates moisture.
Still need to check voltages like you did. Brakes work very well though.
I really like the way you looped the wires to allow for suspension movement. I may redo mine the same way. Seems like it would probably work better.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
