camperkilgore's avatar
Sep 23, 2015
Brake issues resolved....but.....
Wonderful info from forum members helped me solve an ongoing problem with my Prodigy P2 controller intermittently getting SH and OL errors.
I replaced the wires from the Pinbox connection to the brakes. I decided to use 12 gauge wire which is a step up from the wimpy wire that was original. I considered 10 gauge wire which has been used by some, but decided to use 12 gauge. Hope it's enough. I ensured that all connections were very good and I used waterproof boxes under the trailer to house most of the interconnections for the main brake line wires. Brakes work very well now.
My question now is:
Having increased the wire gauge of the trailer harness, I have now noticed that my 2003 Dodge Ram 2500 with tow package has much smaller wires from the controller (Prodigy P2) to the 7 pin connector at the back of the truck. Not sure of the gauge, but they look much smaller than 12 gauge. Looks like the blue wire which is the actual brake command should be larger.
Should I also increase the size of the blue wire from the 7 pin connector at the rear of the truck all the way to the controller? Would that improve braking even more? Anybody done that?
  • TucsonJim wrote:
    The wire size is dictated by the current flowing through the wire. If Prodigy elected to go with a 14ga wire, there is no need to go with a larger gauge further down-stream.
    Makes sense to me, but why does etrailer recommend 10 gauge for brake wiring on the trailer/rv?
  • The wire size is dictated by the current flowing through the wire. If Prodigy elected to go with a 14ga wire, there is no need to go with a larger gauge further down-stream.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
