stickdog wrote:
For proper adjustment and operation of Ford brake controller READ YOUR OWNERS MANUAL.
:R
Really??
Ford controller is brain dead stupid to "setup"..
Hook up trailer, set the controller output with the up/down control until you feel the trailer brakes slow you down at low speed (25 MPH or a bit lower) when using the manual lever..
After that you simply drive normally and if you want more or less braking you can up or down the output to your liking when braking with your vehicles brakes..
You do not want or need the wheels to lockup when setting the output..
Much simpler than a P2 or P3..
