wvbike_99's avatar
wvbike_99
Brake problems
Installed 2 new axles in my RV this winter, hooked up truck (2010 F150) with factory brake controller and it says all is ok, pull camper and applied manual brake lever and very light brake applied even when maxing out the controller to 10. So jacked up wheel and lever will stop wheel but when brake petal is applied nothing, moved to next axle and same result? Tried with engine running and also in gear still nothing,any ideas? Going to have my son hook up his truck to see if its on my truck end. All wires are hooked up and brake lever will activate brakes on both axles???? Help
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
