wvbike_99's avatar
wvbike_99
Brake problems
Installed 2 new axles in my RV this winter, hooked up truck (2010 F150) with factory brake controller and it says all is ok, pull camper and applied manual brake lever and very light brake applied even when maxing out the controller to 10. So jacked up wheel and lever will stop wheel but when brake petal is applied nothing, moved to next axle and same result? Tried with engine running and also in gear still nothing,any ideas? Going to have my son hook up his truck to see if its on my truck end. All wires are hooked up and brake lever will activate brakes on both axles???? Help
  • If manually applying the brakes via the lever on the the controller makes them work satisfactory, then that suggests the controller itself isn't working right in its normal mode.
  • You can check the brakes by using the emergency brake switch instead of the truck umbilical.
    Don't leave the pin out for any long length of time but if you carry a compass around to the axles, and if the magnets are powered, it should swing the compass needle. If you have the wheels off the ground, you can also turn a wheel to check shoe->drum contact.
    As was mentioned, adjustment is key to good brake operation.
    BTW, the Ford brake controller is an inertial controller, i.e. truck needs to be moving for the brake pedal to send power to the umbilical.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
