cekkk
Aug 19, 2016Explorer
Brake question
As we are taking our TT and two other trailers to CA next month I'm taking them all to a mechanic/friend to have axles serviced. Two days ago I towed the flatbed to him and all lights worked as well ...
DrewE wrote:
The breakaway brake battery is only used when the breakaway switch is activated, and plays no role in braking when properly hooked to the tow vehicle.
Add that to all I don't know about wiring.
Non-braking could be caused by a bad ground, a bad brake wire connection, bad brake adjustment, stuck brake mechanisms, bad breakaway brake switch, and probably a host of other possibilities...
