donn0128
Oct 30, 2013Explorer II
RJsfishin wrote:
Brake adjustment has nothing to do w/ braking power ! No matter the adjustment, the same pressure/force is applied to the shoe to drum contact, whether hydraulic or electric brakes. All adjustment does is shorten the time between pedal movement, and actual shoe/drum contact. In the case of hydraulic brakes, adjustment will also lessen brake pedal travel.
Actually it has everything to do with adjustment. Electric brakes use a magnet which when activated is pulled against the spinning brake drum. There is a finite amount of movement of this magnet which rotates while in contact with the drum. If the brakes are too loose the magnet cannot pull the brake shoes out far enough to be effective. Adjustment is critical to ensure that the shoes move out far enough to effect braking. Next is the magnets Weak magnets will also effect braking force.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
