This is my first post to this forum and I am hoping that someone can point me in the right direction. To start with I have 2000 4WD GMC 1500 and I am pulling a 30' x 8.5' v-nose trailer with 3500 ...
I agree the trailer brakes are not working properly.
Does you control have the ability to manually apply the trailer brakes? if so apply them when stooped and try to pull the trailer, the trailer wheels should not roll
I would also replace the brake fluid in the truck. it probably has water in it and is boiling which is causing the pedal to go to the floor. I had this happen in a 34' class A
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
