MNtundraRet
Jul 04, 2013Navigator
The battery(s) ground on the "NEG" post of the battery. Did you remember to re-attach the grounding wire?
If you grounded the "POS" post you re-installed the battery(s) back-words. It may blow the fuse on the converter/charger if left that way.
If two 12v batteries, are they connected in parallel? Two 6v volts must be in series.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
