dougrainer
Nov 17, 2018Nomad
One thing. Even tho the coach batteries are somewhat new. SOME RV's, if the battery disconnect is turned OFF, that disconnects the Coach batteries from the Coach charging system and the coach batteries will go dead after a few weeks. On this type connection, the battery disconnect ON light, if you have one, will be ON, because the ON light receives its signal from the COACH side of the Disconnect relay. This scenario only affects RV's with POWER CONVERTERS. If you have a INVERTER/CHARGER, the batteries are connected direct to the Inverter/Charger. Doug
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
